Just wanted to know what all do I need to change out when I do the intake swap. Diffrent map sensor or can I use the same from the LS1 intake collant lines etc. Thanks
You can use everything honestly. However you want to get the coolant lines for an LS6. your intake will not seat properly if you install straight up without changing them. It is a simple tasak though. Just watch your OP sending unit.
