Anyone make a stainless steel x-pipe for '00 SS?
Thats ceramic coated inside and out too? Looking to building myself a true dual set up. I want all the piping and such to be stainless steel for longevity and rusting purposes. I have FLPs and the off road pipes on there now. Both the cats and off road pipes have 2 different size ends, one being 2 1/2" (mates with the y-pipe) and 3" (that mates with the header collector.) I wanted to keep my off road pipes and cats and do nothing to them. I also want them to be useful and interchangeable. To do all of this, I would need a shorter x-pipe with the front ends (closest to the engine) to be 2 1/2" with the v-flanges. Do they make x-pipes with those type of ends and what I wanted above? If I wanted to do 3" from the collectors back, I wouldnt be able to use the FLP off road pipes or cats. I would then have to buy another set of cats with 3" ends and a set of off road pipes also with 3" ends. That would be a lot of money and for them to have the v-flanged ends. Id like the entire set up to have the v-flanges on the ends for easy installation and removal. Thank you and if you have any suggestions or tips for me, let me know. By the way, if you have a set up like the way I want to do it, please post pics. Thanks again.
Re: Anyone make a stainless steel x-pipe for '00 SS?
I will probably call them tomorrow because I want to get true duals with an x-pipe but still able to interchange my cats and off road pipes. Basically having a true dual set up built from the cats/off road pipes back. But I also want it to go over the axles. I want it to be all stainless steel and to have v-flanges like the FLPs. Do they do ceramic coating? If not, then I would like to get the whole system done. Thanks
