CSR electric water pump install?
Any good write-ups? I suprisingly couldnt find anything that hit the nail on the head here. I have the mechanical pump off the car already, and the new EWP has already been modified to fit in the housing. I just dont know what to do with the freeze plug and the two electric wires coming out of the electric impeller??
What de Hell?
Thanks for any help cant wait to get the damn car back together.
What de Hell?
hashtagBMW
1 1/8 freeze plug, put it in from the front.
Blue - Positive
Black - Negative
Run the black to the radiator support ground right next to the CAI and run your power to the air pump fuse in the underhood fuse box. Or to another switched source.
For reference:
Pink - 12v Switched
Red -12v Constant
Blue - Positive
Black - Negative
For reference:
Pink - 12v Switched
Red -12v Constant
1 Post
oh ya! take the coupler off the timing chain i see it is still on in the picture.btw i also used my air pump ignition hot side i just didnt know if you still had your air pump in use.
