Reinstalling heads question.
Old 09-09-2007, 04:12 PM
LS1TechRulez's Avatar
Default Reinstalling heads question.
Ok, its been almost a year since I took my heads off. I am getting ready to put them back on and I have a few questions. Sorry the search function has not been working for me.
First, can I reuse my headbolts? All I have right now is a gasket kit.
Second, should I get new pushrods?
Third, is there anything else I should know/do before I get going?
thanks
BTW this is pretty much a stock car and I do not plan on pulling the heads again.
Old 09-09-2007, 04:18 PM
NemeSS's Avatar
1-no on the bolts
2-only if any are bent.
3-clean all debris/fluid from bolt holes on block,
Old 09-09-2007, 04:19 PM
Roger that...Thanks
anything else?
Old 09-09-2007, 04:21 PM
98Camarod's Avatar
this is a very useful site www.ls1howto.com It helped me out a great deal on my swap.
Old 09-09-2007, 04:23 PM
SmaknaSS's Avatar
thanks
This might help you a little with the head install.
>>>>>>>> http://www.ls1howto.com/index.php?article=2
Old 09-09-2007, 04:33 PM
thanks guys. just ordered some headbolts from gmpartsdirect.
any suggestions on where to get the pushrods? Or should I get hardened pushrods?
Old 09-09-2007, 04:42 PM
98Camarod's Avatar
If you plan on leaving it stock then if the push rods are not bent then I'd reuse them. It shouldnt be a problem.
Old 09-09-2007, 04:46 PM
Well the thing is they are all perfectly straight except one has a very very small curve which is almost unnoticeable. I don't want to take any chances so I figure I should just purchase some new ones.
Old 09-09-2007, 04:54 PM
Tram's Avatar
A very small curve which is almost unnoticeable sounds bent to me..
Old 09-09-2007, 05:35 PM
98Camarod's Avatar
I agree. I have some stockers if you need them.
Old 09-09-2007, 06:04 PM
3.4camaro's Avatar
I have some stock ones too.
Old 09-09-2007, 06:11 PM
98Camarod's Avatar
I seen the manly thread I havent taken the time to look at the cam that well. Does the wire feed through it?
