Oh yes. It's my turn, PCV + STS + No Oil Pan tapping
Okay. PCV question FTL. There have been so many, but... Right now I have a ton of 3/8" hose along w/ a T-fitting, some caps, a catch can, a k/n breather. Can I make a vented functioning system out of that? I can't route the breather to the oil fill because my return is going in there, no chance in rerouting that to the oil pan.
Can I route the breather on the front passengers port. And T- the back ports and run them to the catch can to a check valve which goes intake manifold? Would that work and end up capping off the throttle body?
And... someone posted that they gained something like 60rwhp on the dyno after they messed w/ their Pcv setup. I'm not disputing that, but I'd like to know how that is possible.
The people with a breather are putting their oil return in other places. You could put the oil return in one of the valve cover breathers. If you are not having alot of blowby, you could put it in the passenger front breather port that used to go to the TB. Thunder Racing sells a nice billet breather for the oil cap.
Interesting. I never thought of that. I could pick up a breather tomorrow. Then I would need to craft up a way to connect the oil return quick disconnect to the 3/8" hose. I shouldn't be getting much blowby, I just got my engine built. However, the only reason I'm doing this is because I lost about a quart in 1300 miles. Seems like a LOT to me.
