coolant level??
coolant level??
so just recently my low coolant light has been on and i keep having to top off the overflow tank...the wp was just changed and i dnt have a blown head gasket...the car runs alittle hot too..what can be the problem? i bleed the system good
Sounds like a small leak, probably only shows up under pressure. I had the same prob a while back, never had any signs of coolant under the car, eventually it got worse then I found where it was coming from.
Take it to a rad place and get them to pressure test it.
Sara Lou
Sara Lou
