No DTC, car runs terrible
As stated I have no DTC, but the car runs terrible. wont tickover, wont pull,
I have spark plugs that one bank look tan colored, the other bank are dark black, but not wet.
no codes
one o2 sensor that looks like normal curves
one o2 sensor that looks like it is erratic
have swapped both o2 sensors for the rear ones (dont use those in my application) .....no effect
stock plugs, 50 thou gap
this started after a 30 hot laps a track day, no missed shift, nothing mechanicaly sounding wrong
any suggestions befor eI start to tear into it
no codes
Updates
I reflashed the ecu with an old backup tune, which seemed to clear up some of the issues, (the car runs now, but cant tickover till warm). but I am having difficulty tracking down why it wont run well
so far I have
cleaned all injectors (no effect and no debris found)
swapped all plugs from one side to the other, no effect
swapped plyg wires, no effect
swapped coils across, no effect
checked exhaust manifold temps, side with black plugs was 20 degrees colder than the other side, with all 4 cyls on that side reading similar
If i disconnect the rich bank coils while running, the engine still runs but stumbles
if I disconnect the other side coil whille running, the engine dies immediately
Tomorrow I will remove the exhaust and try running without cats, perhaps running rich for a while has blocked the cat with carbon deposit....is this a posibility.
I have hp tuners, so can scan this, I can see the o2 sensor looks different from one side to another, but this is the second o2 in a fewmiles, need to seewhat is causing the problem
can also see the STFT and LTFT one side are way different, 15% adjustments from stock. Never seen thesemove around more than a few % before.
thanksfor any ideas....... currently checking the integrity of the loom......damn there are a lot of wires to check!!
so far I have
OK checked the loop, pin by pin, found no irregularities.
swapped out the o2 sensor, which was a little dark and sooty, car runs better,but still not right.
I will see if i can get a scan tomorrow, and post a shot of the sensor
Dirty MAF?? i just ran into that with my camaro. threw no codes but just ran like ****. cleaned the MAF and wow what a difference. maybe check to see if the little wire things inside the sensor are good and clean.
maf cleaned, sensors checked, swapped another o2in, car runs, but as soon as it starts, LTFT and STFT start tomove one side
I cant post a scan here, but if you have hpt, you can see the post on the hpt site
http://www.hptuners.com/forum/showth...982#post103982
any suggestions much sppreciated
checked the manifolds, could nip acouple up a little, perhaps 1/8 turn, but no more
also took rocker cover off, this has not been run for a couple of weeks, is this normal condensation, or a water leak.
also thought oil pressure was a little low, 30, not the normal 38 i normally see
any thoughts..............
checked the cyl balance test on hpt
1 89
2 92
3 89
4 91
5 95
6 90
7 93
8 89
this is an average of 3 readings for each cylinder, none of them varied more than a couple of pointsfrom each other for each cylinder
started a compression test, did
1 220
3 230
5 225,
then the bloody comp gauge stopped holding pressure, couldnt see a thing.
went and bought another, but as the plugs were all out, and it took acouple of hours or so to get a replacement, the test was definately "warm" not "hot"
results.....
1 200
2 115
3 240
4 130
5 220
6 145
7 210
8 125
this was with all spark plugs out, and yes rechecked a couple each side to make sure I did not misread the gauge......
Think I see a pattern............
1 89
2 92
3 89
4 91
5 95
6 90
7 93
8 89
1 220
3 230
5 225,
results.....
1 200
2 115
3 240
4 130
5 220
6 145
7 210
8 125
im no expert but it sounds like you got some bent pushrods
ls1 car are known for this!!! bad shift or a miss shift or a over rev
ive seen it a couple times and its happend to my own ls1
it a cheap fix
it a cheap fix
