View Poll Results: best head for my application
Voters: 47. You may not vote on this poll
PRC 5.3 VS PRC ls6 VS patriot LS6
i had another thread that got very little attention so im guna make this a poll. ive seen a couple of these threads so im sure yall are tired of seeing them. none of them gave me the answers I need. please dont vote based on what you have, or who gave you great customer service. ive dealt with both companies and both are awesome. im needing to know which head will work best with MY application. what gaskets i need to use, how much compressin do yall think is good etc...heres a copy paste from my other thread.
oh, and THIS IS A LS1!!! NOT A 5.3, NOT A 4.8!!! LS1 LS1 LS1.haha sorry for the disclaimer...it seems every time i post on a car site i get people asking if its a 5.3.
99 LS1 (STOCK)
226/226 .584/.584 112+4 XER---TR 7.4's---918's
intake
p&p throttle body
Truck intake manifold
pacesetters/ory/exhaust
asp underdrive/alt overdrive
4.10
A4
3600 stall
FULL BOLT ON
im probably guna spray 125 wet shot through it eventually.
intake
p&p throttle body
4.10
A4
3600 stall
FULL BOLT ON
Wish I could vote, I am really curious how the 5.3's and the LS6 would match together. Both from PRC have shown great results. Other than the compression difference I am not sure what the big difference is. One guy tells ya to go 5.3 and the next LS6. Good luck on decison. I know I will need it when it comes time for me to decide, haha
What exactly is your application? What are your cam specs? Do your pistons have valve reliefs? Are you willing to flycut if needed? The flow numbers of all 3 heads are similar, so I would get the heads/gaskets that put my compression and quench where it needs to be. Kinda hard to determine with the lack of info you are providing.
I have that same Question.I have a trex v2 cam,-2 vr pistons,347 or 408 have not made up mind yet.I like the 5.3 to up compression,But if i go 408 will they be to small.
that answers alot i will go with the ls6 because if i go 347 now later i will do a 427 then switch the ls6.How much can i open the the ls6? i want to go 2.08 or 2.10 can that be done on those heads or should i just go dart 225?
99 LS1 (STOCK)
intake
p&p throttle body
4.10
A4
3600 stall
FULL BOLT ON
My friend made 359rwhp with small cam full boltons 3.73 A4 3600 Stall
Just PRC LS6 Heads swap made 393rwhp and 28rwtq more (I dont remember the exact numbers on the TQ)
Those PRC LS6 Are freaking awesome get them you wont regret it.
PRC 5.3 Also great set of heads if you get them Mill them for more Compresstion.
Cheater cam and PRC LS6 Heads full boltons a4 = 389rwhp ( No fast setup)
Same car,same cam and same boltons with Patriot 59cc AND WITH FAST INTAKE AND 90MM TB= 395RWHP
Originally Posted by TXsilverado
my bad...i copied and pasted the wrong part into the quote of my first post...
99 LS1 (STOCK)
intake
p&p throttle body
4.10
A4
3600 stall
FULL BOLT ON
99 LS1 (STOCK)
intake
p&p throttle body
4.10
A4
3600 stall
FULL BOLT ON
LS1Tech Premium Sponsor
Do a search in the dyno results section bro. I think you'll find the PRC cylinder heads out dyno the competition time & time again.
Here's some resent results I found in the first 4 pages in the dyno section:
PRC 5.3l Stage 2.5
MS3 & Fast 90 486rwhp
https://ls1tech.com/forums/dynamometer-results-comparisons/768555-tsp-5-3stg2-5-ms3-vengeance-ported-fast-graph-inside.html
PRC Terminators 490+rwhp
Fast 90 Big Cam
https://ls1tech.com/forums/dynamometer-results-comparisons/760089-ryans-performance-texas-speed-494rwhp-na.html
PRC LS6 233/239 435rwhp
Mustang Dyno
https://ls1tech.com/forums/dynamometer-results-comparisons/670732-dyno-results-tsp-2-5-ls6-heads-233-239-112-2-a.html
PRC LS6 Heads MS3 460rwhp
https://ls1tech.com/forums/dynamometer-results-comparisons/760837-tsp-prc-ls6-ms3-460rwhp.html
PRC LS6 cnc work & camshaft
Added On Stock LS6 Motor
https://ls1tech.com/forums/dynamometer-results-comparisons/761824-dyno-d-new-setup.html
Independent dyno results are definately the best method for checking a products true power potential. The dyno results section is your best friend when searching for new parts!
PRC 5.3l Stage 2.5
Fast 90 Big Cam
Mustang Dyno
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
