Western Members CA, AZ, NV, UT, CO, NM, HI
FS:2005 LQ4 6.0 long block
Old 09-10-2007, 02:30 PM
LS1Z28's Avatar
Default FS:2005 LQ4 6.0 long block
I'm sell a 2005 LQ4 with 7800 miles on it. It was replaced with a 427 so I no longer need it. SOLD!! I will not ship so don't ask. This is PICK UP ONLY!!!
Old 09-10-2007, 03:49 PM
CaliforniaBoy5's Avatar
great amazing guy here......! hope u sell soon!
Old 09-10-2007, 04:36 PM
raymer626's Avatar
Does it come with anything extra or just what I see in the photos? PCM? intake? valve covers and coil packs? thanks
Old 09-10-2007, 05:03 PM
LS1Z28's Avatar
What you see is what you get. All the other parts were used on the new motor.
Old 09-10-2007, 06:22 PM
Now you have my attention
GTOSE's Avatar
**** I wish...
Bump for ya
Old 09-13-2007, 11:58 AM
LS1Z28's Avatar
No one wants upgrade to a low milage 6.0 liter motor ?
Old 09-15-2007, 05:56 PM
Gearhead125's Avatar
Where are you located, is Yorba linda in NV?
Old 09-15-2007, 06:03 PM
LS1Z28's Avatar
Yorba Linda,Southern California
Old 10-21-2007, 10:26 AM
LS1Z28's Avatar
to the top
Old 10-21-2007, 01:42 PM
Black02LS1's Avatar
Nice engine, I would be interested if i had the money. Do you have the specs on it? Like the cam, heads, hp, or proof of the miles on it?
Old 10-21-2007, 03:04 PM
LS1Z28's Avatar
It was in the truck for 6 months and only driven localy.As for the rest it is a stock replacment Manufactured in aug 05 installed in January 06 and removed in June 06 rated at 345 hp. But you don't have any money to buy it so why would you care?
Old 11-08-2007, 01:46 PM
LS1Z28's Avatar
To The Top
Old 11-10-2007, 01:15 AM
6LITEREATER's Avatar
What else would I need to put this in a 1998 F-Body? Would all the accessories just bolt up?
Old 11-10-2007, 09:11 AM
LS1Z28's Avatar
The only thing I can think of is coil mounting brackets. This engine has center bolt valve covers. The 98 has perimeter bolt valve covers with the coils bolted to the cover. Other than that everything else bolts up and all the sensors are in the same locations. And this motor does come with valve covers.
Old 11-10-2007, 04:54 PM
SVT BAIT's Avatar
IT WAS JUST A QUESTION RELAX
Old 11-10-2007, 08:00 PM
8tsixt's Avatar
Besides what the op said you will have to use your stock oil pan and harmonic balancer as well. you will also need to drill and tap one hole for the alternator bracket as well. I have a similar setup on mine.
Old 11-11-2007, 01:59 AM
Nice, only thing I'm trying to figure out now is if my F13 cam will work. I'm thinking it might not, I think the cam sensors were different...
Old 11-11-2007, 03:14 AM
Nine Finger 02 Z28's Avatar
Yes your cam will work and the sensors are the same...
Old 11-16-2007, 10:14 AM
LS1Z28's Avatar
sold!!
Quick Reply: FS:2005 LQ4 6.0 long block
