Anyone make a 4" output F-body air lid?
going to be running a 4" lingenfelter MAF and a sheet metal intake on the car. Searched around a bit but couldnt find an airlid witha 4" output. Can anyone point me in the right direct or will I be busting out the epoxy and fabbing one up myself?
Kleeborp the Moderator™
Originally Posted by teke184
talk to TSP...they use to produce a lid that fit the 85mm maf sensors
but that was 4yrs ago
My SLP lid outlet is about 4" in diameter, but it'd have to be much larger than that to actually stuff a MAF sensor IN it. Since I don't run a MAF sensor, I just butted a 4" diameter pipe up against it and use a silicone coupler to joint it to the lid. Works for my application, but I don't think that is what you are looking for...
Originally Posted by MeentSS02
They don't make those anymore...
actually typed that one in under a haze....I will be running a 100mm MAF from Lingenfelter and I'm trying to tie into the slp air box ls-1 set-up I have for the car. The SLP air lid only goes to 90mm.
I'm looking for a lid that will bolt into the LS1 air intake set-up that has a 4" output that I can use 4" I.D. silicone couplers to connect the lid to the MAF and teh MAF to the throttle body as referred to by meentss02. and NOT stuff it into the lid itself, sorry for teh confusion.
Meentss02, which lid are you running?
I took a calipers to my SLP lid last night and came up with 90mm I.D. My MAF and TB will both be 100mm I.D. so why have the restriction at the lid after investing in a sheet metal intake, 100mm TB and 100mm MAF....I may have to get creative with some carbon fiber and resin, Just would rather pay someone else for one than get dirty, this project is time consuming enough at this point fitting an LSX based drysump motor into an LT1 car.
Restricted User
I have a Volant intake for sale. It was ported so that a 85mm maf would fit inside so your maf shoule couple right up to it. It is 4" outer diameter. Here is a pick of what they look like. It will flow the air you are looking for.
Originally Posted by studderin
heat gun, + lube
