383 stroker lost power
Old 09-11-2007, 01:50 AM
ATAY383's Avatar
Default 383 stroker lost power
my 383 lost power so can any one give me any answeres on this so i can figure out so i can drag it.
Old 09-11-2007, 03:17 AM
Ralls's Avatar
Details???
Replace engine
Old 09-11-2007, 03:24 AM
ATAY383's Avatar
Default 383 stroker problem
well one day it was fine then all of a sudden it lost power and i thought it could be the vacuum because of my brakes like every time im at a stop sign and push on the brakes my car would pull. so i replaced the master cylinder and then replace the brake booster and it still did it so i thought maybe it could be a vaccum issue cause i heard a vaccum issue could make u loose horsepower.
Old 09-11-2007, 05:49 AM
jasonisdn's Avatar
do you have anything to scan the ecm with?
if not a easy way to check for a vacuum leak is to use a propane torch. cut the torch on but don't light it. with the propane flowing out move the torch around the engine slowly. listen for the idle to change. if it does you found it, if not you don't likely have a vacuum leak.
Old 09-11-2007, 05:12 PM
ATAY383's Avatar
i have c.a.t.s if u can scan that.
Old 09-11-2007, 05:58 PM
jasonisdn's Avatar
ok then you have the cable. ok go download http://www.ttspowersystems.com/DataM...downloads.html
install and it will give you a few free scans. after you do that post the file and we can go from there.
Old 09-11-2007, 10:47 PM
ATAY383's Avatar
thank you.
Quick Reply: 383 stroker lost power
