Gears & Axles - Does anyone make a 9" that supports 3-channel ABS?
squirrels
05-31-2003, 01:53 PM
Title pretty much says it all...do any companies make a 9" rear that will support the 3-channel ABS found in non-TCS F-bodies?
Also, does any work need to be done to modify a 9" to work with the stock F-body suspension components?
NiceTry
05-31-2003, 05:52 PM
i'm pretty sure that moser makes one but i could be wrong
no 3-channel ABS on 9" rear ends. Moser and Strange only offer a 4-channel setup. Currie told me that they didn't offer any setups to retain ABS/TCS.
Camaroholic
06-01-2003, 09:46 AM
That's right. They can get the 4-channel because the reluctors are on the axles, but can't do the 3-channel because the reluctor is inside the pumpkin itself. Nobody's figured out a way to put the reluctor inside the pumpkin (chunk) on a 9-inch yet, AFAIK.
-Andrew
zturbo
06-03-2003, 12:51 AM
I don't know of a 3 channel abs setup for a 9" but i have heard of some people making 4 channel work with 3 channel. How I do not know no abs on my car it weighs too much :D
Steven
1CAMWNDR
06-03-2003, 03:05 PM
Would it be possible to convert the 4-channel signal so the 3-channel system can understand it? Then it would just be a matter of plugging in some different connectors. :drive:
1CAMWNDR
06-06-2003, 12:16 PM
Or maybe weld a ring onto the pinion shaft, kind of like the alternator drive on NASCAR, and bolt the sensor on with a bracket mounted to one of the housing bolts? Would have to be very careful with alignment, and clearance with the suspension completely compressed.......
Could work though........
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
