Western Members CA, AZ, NV, UT, CO, NM, HI
AZ HELP! Throttle cable bracket needed
Old 09-12-2007, 07:59 AM
myfast70's Avatar
Default AZ HELP! Throttle cable bracket needed
no longer needed
Old 09-13-2007, 06:14 AM
SSMOKIN_Y2KSS's Avatar
let me check i think i have one ill get back to u
Old 09-13-2007, 06:17 AM
actually now that i think about it bro if u still have the stock setup with the cruise control n **** ur cables are adjustable i had the same problem a while back if u look on ur throttle cable lines theres little black clip looking things the clip pops up and u can adjust your throttle cable tension i belive its in 2 diffrent spots too
Old 09-13-2007, 06:19 PM
BigDaddyBry's Avatar
^I think the most you can adjust would be about .5 to 1 inch of travel. I had to adjust mine and thats about what I found.
Seems like you could fab a bracket up from scrap, if you had a stocker to copy. Doesn't look like there's much to it, at least it would get you by for now.
