used ls2 heads
used ls2 heads
found a set of used ls2 heads off a 06 gto for 250.00 do you think this is a good deal?
how do these heads flow ported compared to ported ls6 heads?
Thanks
Eric
Thanks
Eric
LS1 Tech Veteran
LS2 heads are the same 243 castings (same heads) as the LS6. Assuming that the heads are in good condition, they have good potential once ported. If you just swapped them with your LS1 heads and didn't change anything else, you wouldn't see much difference in performance.
Steve
Steve
Originally Posted by Snyper
for that price its a GREAT deal and you will show a noticable improvement..even if not ported..maybe not much put +20 at least.
just looked at the ad again and they are not off a 6.0 gto. they are the 317 casting.
price lowered to 175
