need part number for ATI balancer that is SFI
What part number for ATI balancer?
I have no AC and don't need the ac pulley
I am only running the alternator off of it.
It gives me like 6 different ones for my car when I search all of different diameters and some of different materials; Steel or Aluminum/ Steel or Aluminum.
Which is the best one to get?
It needs to meet NHRA SFI specs
engine is a LS1 5.7
Is the underdrive one bigger or smaller diameter? which is better?
engine is a LS1 5.7
Originally Posted by kp
Its just a balancer, thats all it comes with.
You can use a stock length belt but the next size shorter is the one I used.
Also what bolt do I need to buy for the crank?
Originally Posted by brandonppr
So since you use the stock alternator pulley wouldn't that mean that the alternator would slow down?
You need either a new stock crank bolt or I use an ARP bolt.
There are cheaper SFI pullies out there then the ATI, main reason I use it it because its the only one that works with the blower pulley I use. ASP, fluidamper, march, powerbond etc all sell SFI dampers.
Ok I bought that part number mentioned above.
I have a question about it.
The stock balancer has no key/slot in it.
The cranke has no key on it.
The ATI one has a key/slot in it.
Does that matter for anything?
Do I need to put a pin in it or can I just put it on like normal?
