Replacing rear output seal
Im about to change out my leaking rear output seal on my t56. anything i need to know/advice on how to do it??
seems pretty straight forward:
remove driveshaft
pop out seal
lube and put in new one
slide the driveshaft back in, bolt everything back together...and drive
any comments/advice would be appreciated as ive never done this before.
thanx
remove driveshaft
pop out seal
thanx
I don't even silicone the seal since they have a sealer on the outside of the housing of the seal . As for the leak , most of the time rear seals won't leak unless there is another issue like the rear bushing is worn or the driveshaft yoke is worn . The only other real issue is dirt on the yoke rubbing in and out on the seal .
