4L60E question???
Old 09-14-2007, 11:27 AM
mattz28zx6r's Avatar
Default 4L60E question???
Are all planetary gears the same in all 4L60E's?
Old 09-16-2007, 10:32 AM
dknight16's Avatar
Yes. They don't have model mix variations like shafts (if that is what you are asking). Gear sizes & tooth counts are the same for all models. Of course you do have the 5 vs 4 pinion carriers in 4L65s and 4L60s (respectively). Even then, the gear ratios, however, are the same.
F & Y Car Reaction Carriers have the crimped on oil deflector and slightly different pinion pins. But again, the gears themselves are the same.
