Florida Members Fun, sun and LS1's
Transmission shop NEEDED BAD!!!!
Old 09-14-2007, 03:06 PM
ND4SPD _SS's Avatar
Default Transmission shop NEEDED BAD!!!!
anyone know a good transmission shop local in Orlando? I need a shop that has Tec 2 that can measure Torque converter slippage. RPM thinks my converter is going bad. I am trying to save my trans before it goes too. I appreciate any help.
thanks in advance.
Old 09-14-2007, 03:52 PM
92slowmaro's Avatar
i work at a dealership. let me see what i can do and more than likely i can hook you up with a tech 2 and well see exactly whats going on with your converter slipage issue. pm me.
Old 09-14-2007, 08:21 PM
Mike Norris's Avatar
I have a Tech2 and will be at the shop in the morning. Looks like you are in Winter Garden so it should be close for you. Just call me in the AM if you are coming by. 407-616-2518
Mike Norris
Old 09-14-2007, 09:02 PM
TLewis4095's Avatar
Mike Norris
Mike can probably work out a fix with tuning if it is not a hard problem.
Quick Reply: Transmission shop NEEDED BAD!!!!
