oil pan question
Old 09-15-2007, 07:15 AM
forcd ind's Avatar
Default oil pan question
Moroso makes an adapter oil pan, but it looks like stamped steel-one of the things touted about the ls engine is the orig. cast pan is also part of its structure-are you really losing any strength going to a stamped pan
Old 09-15-2007, 07:49 AM
QSPres's Avatar
A better question is will you stress the engine enough to need the extra strength?
Old 09-16-2007, 07:29 PM
Kenova's Avatar
Although the cast aluminum oil pans do contribute somewhat to the structual strength of the engine, they are not critical. The main purpose of using the cast aluminum pans is for Noise, Vibration, and Harsness (NVH) control. In other words, it's just another way to quiet things down so the socker moms don't whine about noise.
Using a stamped steel pan will not cause any structural problems.
Ken
Old 09-16-2007, 10:58 PM
pist0lpete's Avatar
Also, from what I have seen of the stamped steel pans is that they have a substantially thick rail that acts as the bolting flange which I am sure adds strength. Is it as good as the stock aluminum pan? I can't be sure, but either way it should be fine.
Quick Reply: oil pan question
