4l80e in a 05 GTO?
Old 09-16-2007, 07:43 PM
T-Bones Goat's Avatar
Default 4l80e in a 05 GTO?
I'm looking for anyone who has done a 4l80e swap in a GTO. Has it happened yet?
Old 09-17-2007, 01:00 PM
Bersaglieri's Avatar
Probably since when you get to the point of needing a 4L80E in a GTO you'd have already done a solid rear axle swap. I dont think the GTO is a good candidate for a 4L80E.
-Dustin-
Old 09-17-2007, 06:00 PM
I am doing a Ford 8.8 as we speek. The 4l80 is the only transmission that I know of that will hold the kind of power I'm looking to make and also have an overdrive.
Old 09-17-2007, 06:06 PM
We'll I guess your going to pioneer it, good luck then.
-Dustin-
Old 09-17-2007, 07:33 PM
-Dustin-
Being the first isn't always the easiest, that's for sure. Thanks for the encouragement!
Old 09-17-2007, 07:39 PM
14 Second Truck Club
mzoomora's Avatar
You could always do a TH350 with a gear vendors.
Old 09-17-2007, 07:49 PM
Sorry for the ignorance but what is a gear vendors?
Old 09-17-2007, 07:55 PM
mrialsm4's Avatar
gear vendors is an overdrive unit that bolts into the place of the tailshaft. It gives an overdrive for each gear so you effectively have a 6 speed th350. If I were going the gear vendors route I'd opt for a built powerglide/gearvendors combo. You'd have 1st, 1.5, 2nd, 2.5 (OD) I'm not sure of the ratios though.
Old 09-17-2007, 08:10 PM
That sounds really cool. What kind of price range?
mrialsm4's Avatar
quote from their site on the glide/GV combo.
Most cars with 1200hp or less will also find benefit in using 1st-over which will net a really nice 4spd spread of 1.76, 1.33, 1.00, 0.78.
mrialsm4's Avatar
t-bones, you have pm
Old 09-17-2007, 08:19 PM
mzoomora's Avatar
In a heavy car like a GTO you would need either a lot of gear or a LOT of power to pull that first gear. That is a nice tight gear set though. The 4L80E can also be set up to use OD in any of the first 3 gears, basically being a 6 speed. They are basically just an electronic OD TH400.
Old 09-17-2007, 08:52 PM
Those are some really tall gears but the spread is really nice and would probably work great with my Procharger once I got rolling. I like the first gear of the 4l80 which is also the same in the TH400 I believe.
Old 09-18-2007, 06:18 AM
Yup the first three are the same as the TH400, only it has the .75 OD.
-Dustin-
Old 09-18-2007, 06:15 PM
383lt1impala's Avatar
well i 4got what magazine did it but they put a th400 in a gto with a 6speed conversion but im pretty sure u can find it if u yahoo it
