FAST double bank wideband
Old 09-17-2007, 11:08 AM
always faster's Avatar
Default FAST double bank wideband
I got a FAST double bank wideband.Everything from the install to the basic worling fonction are really easy.
I also purchase the rpm module to have a precise way od knowing what AFR i was running at each rpm.I know that the FAST module can record and playback the file without a pc but...
Is it possible to log a test run and put i in my laptop after or the only way to read it is with the FAST module?
Thanks
Old 09-20-2007, 07:03 PM
NVR_SPDS's Avatar
If im not mistaken, it can only be replayed on the module itself.
