Problem with car starting
So I have stroked sb in my Chevelle. I decided to post on here since there are so many knowledgable people on this site. I was having some problems with my starter(powermaster torque) which apparently is uncommon. I was told to have it rebuilt which I did.
I put it on and the car still didnt want to start just like before. We did get it to finally start. Stopped at a gas station, wouldnt start for 20min. Went to a car meet, started up right away when we left. Then I had some guys looking at the car to buy it and it wouldnt start at all. It sounds like when you turn the key like it is hitting the flex plate. I dont think it is the starter, but I cant seem to figure it out. Any help would be appreciated.
-Jason
-Jason
I'm sure you've checked that battery first? Pull the flexplate cover and have a look at it, maybe some teeth are missing but since you say it sounds like its hitting it I doubt that, have you tried a different starter?
I havent tried a different starter, but this one was just rebuilt. A regular starter for a sb wont fit. I'm going to ask the guy thats does the work on my car what he thinks, and I'm sure he may have to pull a couple things apart. Its acting like it doesnt want to crank all the way or something. I dont have a clue.
Yes the flexplate has teeth around the peremeter of it that ste teeth of the starter gear engauge, if some of those teeth are missing then the starter would just spin without spinning the motor.
is the starter shimmed at all because a body of mines car would turn over and make a grinding noise and then it just sounded like the starter was spinning, his g/fs dad told him he didnt need the shim it was ony .010 of an inch and i said well it was shimmed when i pulled it of so it needs to go back on, he put the shim on and it started right up
