TH 400 flex plate??? Please Help.
Old 09-17-2007, 02:34 PM
sscrazy's Avatar
Default TH 400 flex plate??? Please Help.
Let me bring you up to speed first of all. I am doing a t56 to 400 swap. I bought a flexplate from a guy on here and I went to install it, and I notice that the dowel on the crank does not fit in the holes on the flex plate. The flex plate hole where the dowel goes is threaded
Also it is a Callies crank that it is being bolted to , not a stock ls1 crank. Does that make a difference? Does the flex plate not need a dowel? Also do you think I need a different flex plate? It has a spacer for the 400.
Old 09-18-2007, 12:26 PM
sscrazy's Avatar
Anyone?
Old 09-18-2007, 01:40 PM
Race your car!
JL ws-6's Avatar
what kind of flexplate is it? if it's not an sfi apporved one, I'd suggest getting one. Hughes makes a nice one that's not too expensive and works good... I've had one in my car for a year now and it's been fine.
Old 09-18-2007, 02:17 PM
98turbls1's Avatar
My meziere has a provision for a dowel pin off of the crank... Maybe you should check them out.. Definitely one of the nicer ones out there...
Old 09-18-2007, 03:29 PM
sscrazy's Avatar
I think it is just a 98 flexplate, which i am told are stronger. Where do I find the Hughes flexplate?
Old 09-18-2007, 07:42 PM
Race your car!
JL ws-6's Avatar
do a search for huges racing transmissions on google. Eastside is a Hughes dealer, you can call them and they could order it for you as well if need be.
Old 09-18-2007, 07:43 PM
Race your car!
JL ws-6's Avatar
Oh, the meziere is an awesome piece too, but I'm pretty sure it's alot more $ then the hughes is though.
Old 09-18-2007, 08:24 PM
BTLFEDSS's Avatar
I used a TCI bought i have a stock crank,not sure if it will work with a dowel
BTLFEDSS
