mufflex bump stop
Old 09-17-2007, 08:45 PM
hokie00 TA's Avatar
Default mufflex bump stop
i just installed my pacesetter headers and ory and the pipe hits on the driver side so i bought the mufflex bump stop and i just dont know where to put it i was curious if some one could take a picture of theres and show me where to put it.
Old 09-17-2007, 08:51 PM
Grifter's Avatar
I am not sure where it bolts to either but doesn't it use an existing hole?
Old 09-18-2007, 04:32 AM
hokie00 TA's Avatar
yea it should but what one and how do you place it.
Old 09-18-2007, 06:51 PM
hokie00 TA's Avatar
nobody knows where this goes to do the best job.
Old 09-18-2007, 07:06 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I will see if I can scrape up a pic of the old one I had.
Old 09-18-2007, 07:36 PM
Z28LS1camaroguy's Avatar
it goes where the heat shield bolts are, it slides under it i believe i cant remember its been so damn long. not hard to find basically right under the drivers seat.
Old 09-19-2007, 04:23 PM
radz282003's Avatar
I ended up drilling a hole in the crossmember and screwing it into that. I had no problems.
Good luck.
Old 09-19-2007, 04:49 PM
Grifter's Avatar
I was actually just reading over an old GMHTP mag and they had Mufflex installing one of their bump stops. It looks like it was right under the driver seat like stated above.
Old 09-19-2007, 07:36 PM
hokie00 TA's Avatar
thanks that helps some but a pic would be even better but thats a start.
Old 09-20-2007, 08:40 AM
Grifter's Avatar
Sorry I couldn't help more, I never installed one.
Old 09-20-2007, 10:15 PM
rsodeputy61's Avatar
mine came with instructions...was supposed to go on the heat shield bolt (10mm) but my O2 sensor was in the way. had it welded to subframe further towards i pipe connection and it works great.
Old 09-21-2007, 04:00 AM
camaroguy26's Avatar
I didn't have the original y-pipe bracket that slid into the tranny bracket. But I took the mufflex bracket and bent it straight, drilled another hole into it and bolted it down to the tunnel brace. Just have to drill it about where the bend was and turn it just right for the clamp on the y-pipe, but it completely stopped every bump and rattle I had The y-pipe was hitting on the tunnel brace, but here is a picture of mine. I got new headers and y though so this old setup is toast sorry the pictures aren't the best for the bump stop but it's all I had.
Old 06-12-2011, 05:22 PM
Team Hopt's Avatar
Bump
I also have the same question, the directions are not very clear. Does anyone have pictures of this mounted?
Thanks.
Old 06-12-2011, 07:26 PM
sjsingle1's Avatar
poly or solid MM............no stop needed
Quick Reply: mufflex bump stop
