Corvette Performance - Ran my 04 Z06 at the track
Venomystic
09-17-2007, 11:38 PM
Pulled off a 12.67 @ 112.87 on Goodyear Eagle F1 Supercars with a 2.028 60ft on a humid night around 85 degrees. Would like opinions, my car is bone stock and I just wanted to see if I was getting good times. I just want to learn how to actually drive my car before I start to mod it. I was slipping the clutch around 2800RPM's and when it inched out I would drop it and pedal it, then powershift through the gears. Any better ways of going about it on streets? I think the car had alot more in it.
Thanks.
mdhmi
09-17-2007, 11:40 PM
Your doing fine. With good weather and some practice you'll be down in the low 12's.
robz*
09-18-2007, 08:50 AM
Thanks.
-Try coming out a little hotter and being smooth without pedalling it and just a slow squeeze to the floor.
-On the 1-2 try shifting a little slower(no powershift) to avoid excess wheelspin or wheelhop
-Try doing a burnout and lowering the tire pressure 24-26ps
-Try shallow staging,just tripping the 2nd bulb
-Try staying behind a few cars with slicks and line up in their tracks.
-Try running with a 1/8 tank of gas for your last few runs.
I just gave you a half a second of info. Go get'em bro.
1badasvt
09-19-2007, 08:37 AM
I give You "props" that You went to the track!!! :rock:
ps,..I'm new to this Forum,but have been on CF for over 2 years!
50_Dave
09-19-2007, 08:52 AM
Good job andrew! You already ran better times then i did with my z06 stock.
Venomystic
09-20-2007, 09:57 PM
Thanks alot, will try my best this sunday.
Venomystic
09-20-2007, 09:58 PM
Thanks dude, you going to be out on Sat?
lafnlt1
10-08-2007, 11:16 PM
ran 12.52 @ 114.46 completly stock on a cool night on the stock goodyears still at 32 psi first pass out just getting there and got lucky
03 Z06
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
