Testing our GTO Gen-TTR Intercooled Twin Turbo System
Old 09-18-2007, 04:41 AM
Street Tuna's Avatar
Default Testing our GTO Gen-TTR Intercooled Twin Turbo System
To give you some idea of the sort of durability testing we have done with the GTDW series turbochargers as found on our Gen-TTR Intercooled Twin Turbo system we sponsored the GT Autosound LS2 Stroker (6.6 L) with a pair for the Drift Australia series. What these guys do is punishing to say the least!
Running in a harsh and high temperature environment wear rates are accelerated beyond normal road/track use by a magnitude (we reckon) of around 10X - 15X. Getting through a season untouched when used in these conditions is excellent and around a conventional OE limit. So far we are halfway there with no issues and wear within expected specification (less than 0.2%). Heres what these animals do to a pair of harmless turbos...(from QR last month)
http://www.youtube.com/watch?v=q6G1X7aA7B4
By the way thats on 275/18 Toyo R888 semi slicks, and all the infield sections you see on the video are roll on in fourth gear, note there is zero shifting of the box like you get with little engines
Old 09-18-2007, 05:57 AM
Websy21's Avatar
Interesting, I'd say thats a fairly harsh environment Say how long does a set of tires last doing that, LOL
Old 09-18-2007, 06:13 AM
firehawk123's Avatar
nice vid mate is it the same turbos that we receved from you for the holdens.
Old 09-18-2007, 06:59 AM
Yes same turbos as the Holdens/GTOs Firehawk
A set of tyres lasts around 2 laps like that
Old 09-18-2007, 07:33 AM
1INSANEGTO's Avatar
What are the specs on that intercooler radaitor setup?
Old 09-18-2007, 08:03 AM
Its a custom piece locally made to fit in the front of a Skyline...and unfortunately it doesnt work very well (the car has to run a second radiator in the trunk)
Old 09-18-2007, 09:27 AM
1INSANEGTO's Avatar
Anymore pics? I see that the front has been cut to make this fit also.
Old 09-18-2007, 11:35 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Very cool. What clutch?
Old 09-18-2007, 03:51 PM
frcefed98's Avatar
Looks like a ton of fun. Thanks for posting the vid.
Old 09-19-2007, 02:21 AM
It has a Textralia Exoskel Twin Plate I believe
Old 09-19-2007, 06:37 AM
chuntington101's Avatar
what are the upper HP limits of the TTR kit?
thanks Chris.
Old 09-19-2007, 03:50 PM
TTR kit will make a good solid 750rwhp on a GTO under the right conditions without exceeding 15psi of boost
We aim more for the torque numbers though, and as you will find if you study some of the results there arent too many TT kits that make the ftlb readings at the same power levels we do
Old 09-19-2007, 06:45 PM
cpt_bimes's Avatar
^but do they have to hack up the front radiator support and have a bunch of custom parts like that kit picture above?
Old 09-19-2007, 07:33 PM
stevieturbo's Avatar
If you own an R34 Nissan Skyline with a twin GenTT twin turbo LS2....then I think some cutting might be required, as with any major conversion.
If however you own a car that they make a bespoke kit for....no cutting like that should be required !, like the Monaro's/GTO's, F-Body's etc
Old 09-19-2007, 10:26 PM
cpt_bimes's Avatar
o this is in a skyline...i see...yeah hacking is permitted then
Old 09-19-2007, 10:52 PM
jamesSS's Avatar
Very nice.
Old 09-20-2007, 05:44 AM
Yep if you have a Skyline and want to fit a GTO kit you have to hack the thing half to death
So not only do you get good ol LSX power, you get to hack up a ricer in the process. Must be the ULTIMATE kit
