$2500 dollars
Old 09-18-2007, 04:39 PM
SSANDMAN's Avatar
Default $2500 dollars
just traded my 70 camaro 383 for my 2000 Camaro SS m6. i want the old school cammed sound and fast horsepower. my budget for the time being only a mere $2500 including shop labor (not enough time or workspace of my own) only mods on car now are torque arms eibachs and lowered.https://ls1tech.com/forums/newthread...newthread&f=4#
Mullet
Old 09-18-2007, 04:50 PM
sidewayz28's Avatar
get your self a custom ground cam. ~$400.00 ?
LS6 intake- ~$300
Long Tubes- ~$300
Dyno tune- ~$500
Tires- ~$400
you could get more crap.. just throwing that up there
Old 09-18-2007, 04:55 PM
SSANDMAN's Avatar
problem is that the car is lowered and railroad tracks, speed bumps and steep driveways are already a problem. long tubes i assume are out of the question for me.
Old 09-18-2007, 07:42 PM
8a8mfh's Avatar
If thats the case then so is that old school sound.
Old 09-18-2007, 09:53 PM
sidewayz28's Avatar
and then there would be pretty much no reason to do any of those mods i just listed unless u wanted to choke the **** out of your motor.. your call, i was just giving you advice sir
Old 09-18-2007, 10:12 PM
Rowin Gearz's Avatar
You could go with a mid length like Mac. They will leave some power on the table when compared to long tubes, but it should solve clearance issues and free up your exhaust for that cam.
Old 09-19-2007, 08:06 AM
The Black Mamba's Avatar
A proper cam swap is going to cost you over $1,000. $400 is just the cam itself. You will need much more than that to get it done right...
Old 09-19-2007, 10:25 AM
00TurboTA's Avatar
Either get more suspension components and bracing components or get a new rear end.
Old 09-19-2007, 11:52 AM
BrandonDrecksage's Avatar
I think most speed shops charge around 1500-1600 for a turn key cam swap. Turn key meaning everything you need to install the cam, the install and tuning. Also, get some headers installed at the same time and that should set you up nicely. Keep in mind that adding power could cause some stuff to break. So make sure you have cash to fix something. i.e. if the rear end breaks or more than likely, the stock clutch(if its still stock) will start to slip.
Old 09-19-2007, 01:14 PM
TA1364's Avatar
I keep seeing posts where ls6 intakes are $300, where the hell do you get that? The slp with egr is 5XX
Old 09-19-2007, 01:38 PM
that is cause slp is expensive. Look at junk yards with wrecked cars or a ls1tech member.
Old 09-19-2007, 02:31 PM
chavez885's Avatar
Then you need some different springs. Longtubes helps bring out the lope
Old 09-19-2007, 08:25 PM
180ls1's Avatar
ls1sounds.com figure out what you like
texas speed makes some agressive cams like the ms3 or ms4 they have a good lope
Old 09-19-2007, 08:36 PM
sidewayz28's Avatar
yeah......if your retarded enough to buy a new one from SLP... its called FOR SALE section .. just giving you **** man
Old 09-19-2007, 09:34 PM
TA1364's Avatar
yea its cool, im just trying to figure out wat i want to do to run 12s without nitrous or new converter.
Old 09-20-2007, 01:38 AM
sidewayz28's Avatar
N I T R O U S actually if i was at your level.. converter will probably do NICE!
its funny how the mod bug works man..
1st was exhaust, then came along the cam + dyno tune, then the heads and stupidily expensive intake & TB, then the nitrous.. what next man? what next?
Old 09-20-2007, 12:10 PM
TA1364's Avatar
I no a converter will pick it up but it will suck for DD
Old 09-20-2007, 02:30 PM
not all converters suck for dding, but the stock one does sure suck for drag racing.
