New Product: GT45F and GT45FX Non-ball bearing now available
Old 09-18-2007, 07:48 PM
LS1TECH Sponsor
DrTurbo's Avatar
Default New Product: GT45F and GT45FX Non-ball bearing now available
The GT45F NON-DBB is now avialable. The unit is built on the GT42 chassis like the current GT45. Its available in both T4 and T6 housings. The turbine wheel is an 11 blade LDP (Low Drive Pressure) design instead of the current 12 blade turbine. Its an 87mm, so its a very nice upgrade for the GT42 owners that have the current 82mm turbine wheel that are choking up top. The compressor wheels available are, 70mm billet, 74,76mm, and 78mm. The new LDP turbine coupled with the 78mm compressor wheel will yield an output of 111lbs/min.
Units start at $1699 for GT45F
Only option is stealth Race cover, which is the GT45FX. Cover is a .96A/R comp cover and is good for additional 75-100hp gains. Also cover is ported shroud without re-flow slot so is legal for some classes not allowing re-flow covers.
Cover option is $199
Old 09-18-2007, 08:02 PM
Josh@KY-Turbo's Avatar
Nice.
Old 09-18-2007, 08:34 PM
SSilverSSurfer's Avatar
interesting.
Old 09-18-2007, 11:25 PM
John Wilde's Avatar
Two would be nice!
Old 09-19-2007, 09:27 AM
LS1TECH Sponsor
DrTurbo's Avatar
Yeah it would be nice with 2 in the front grill....hehe
Old 09-20-2007, 10:26 AM
LS1TECH Sponsor
DrTurbo's Avatar
We have one unit that was built this weekend and final dyno #'s as of this morning are 991rwhp/888rwtq on a 306ci R-block windsor running through a 6spd cobra tranny @23psi. This was the GT45F-78. The X cover was not ready in time. Track times this weekend hopefully if the customer can get a few fuel issues worked out. Stay tuned.....
They are great #'s but the real #'s will be at the track.
Old 09-20-2007, 01:42 PM
JustinOlson's Avatar
Can these be had with 1.15 a/r divided turbing housing?
Old 09-20-2007, 02:04 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yes all the same housings as is avialble for the GT42's
In T4 flange
1.01
1.15
1.28
1.44
T6
1.01
1.15
1.23
Old 09-20-2007, 03:06 PM
frcefed98's Avatar
Graphs and post some vid please.
Old 09-20-2007, 03:29 PM
LS1TECH Sponsor
DrTurbo's Avatar
I will see what we can get him to hook us up with.
Old 09-20-2007, 04:58 PM
NA$TY-TA's Avatar
Sweet
Old 09-20-2007, 06:46 PM
njc.corp's Avatar
what hp are these rated to-can u brake it down for me-
Thankyou-
Old 09-21-2007, 09:05 AM
LS1TECH Sponsor
DrTurbo's Avatar
Thankyou-
The GT45F-78 is 1200, with the FX compressor cover its (1275hp).
The the smallest model is the 70mm billet, and its rated 975hp and (1050 w/FX comp cover), which is a good deal more then the GT42-70 which is 850hp.
Old 09-21-2007, 07:57 PM
njc.corp's Avatar
Cool
what is the gt45f-78 with the fx compressor worth $$$?
it states in the first post( starts from $1699.00) do u also ship worldwide?
email me some more details in a pm if u want-
Thankyou for your time-
Old 09-24-2007, 10:34 AM
LS1TECH Sponsor
DrTurbo's Avatar
The GT45FX is only $149.99 more then the standard GT45F. It comes with the race cover and adds around 75-100hp above the standard cover.
Yes we do ship worldwide.....
Old 09-30-2007, 01:23 AM
How does a GT45F-78 compare to a gt4580r? What is the approximate spool difference between the two? Are there any BW turbos in this power range that are more efficient than the above two?
Regards,
Justin
Old 09-30-2007, 02:28 AM
njc.corp's Avatar
Cool
thankyou for the quick reply- i will give it some thought-
what are we talking about in freight wise 70-90 pound weight?
Thank's in advance-
Quick Reply: New Product: GT45F and GT45FX Non-ball bearing now available
