what size pipe thread is the oil sending unit?
Old 09-18-2007, 10:02 PM
DCx
DCx's Avatar
Default what size pipe thread is the oil sending unit?
my engine was missing its sending unit. i dont want to buy a new one to just plug the hole in the back of the block. what size are the threads?
Old 09-18-2007, 10:45 PM
89 formula350's Avatar
the search showed m16x1.5 thread btw it's not a pipe thread. the sender uses a gasket
Old 09-18-2007, 10:58 PM
DCx
DCx's Avatar
what should i do to block it off, without spending $45 on a new one to use as a plug?
Old 09-18-2007, 10:59 PM
bczee's Avatar
If you plug it, What will you be using for a Oil Pressure gauge....?
Old 09-18-2007, 11:24 PM
sawzall wielding director
G-Body's Avatar
You could always use a metric bolt. Just grab a M16mm x 1.50 bolt, the sender is ~ 2cm long so you would probably have to cut the bolt length down to fit. There needs to be a seal on it, the factory uses a aluminum washer on the sender but you could also use a copper washer (think oil drain plug gasket)
Old 09-19-2007, 12:23 AM
DCx
DCx's Avatar
sweet. i ordered 2 (on accident) oil pan covers (located next to the oil filer) i planned on drilling it out and using my autometer sender there.
just like the sticky says to do.
by the way, this is going in a 69 camaro
here are some pics of the oil bypass cover next to my autocraft oil filter adaptor.
Old 09-19-2007, 11:25 AM
Thaniel's Avatar
I believe you can get drain plugs this size from the local autoparts store.
For my motor I bought an adapter to go from the M16x1.5 to a standard oil sender thread and mounted it in the LS1 location. Seemed simple enough if you have the room.
Attached Thumbnails what size pipe thread is the oil sending unit?-154-5424_img.jpg   what size pipe thread is the oil sending unit?-154-5425_img.jpg
Old 09-19-2007, 11:26 AM
rao
rao's Avatar
It i s a common oil drain plug size - any decent auto parts store will have what you need.
Quick Reply: what size pipe thread is the oil sending unit?
