Mickey Thompson vs Hoosier slicks?
I have a set of Hoosier 29x9 DO5 slicks and I only picked up .25 in et and less than 1 mph over my Nitto 275/60-15 DR's. The Hoosier is 1" taller and the Nittos are 2" wider, so the DR should have a larger contact patch so I would call it pretty even. In a nutshell, I was a little disappointed with the full slick, I was expecting a lot more than a 1/4 of a second out of them.
DANIEL6718-Most people use m/t tires because they are the most popular. Walk in to a tire store around my place and m/t's are on the shelf all others must be ordered.That dont mean M/T's are the best. I have tried M/T et streets(hi-1.6 60 foots)ET drags and hoosier hi-1.5 to low 1.6 60's) as well,all were wrinkle wall tub tires. The M/T's streets didn't hook well at all for me,the et street sucks and the drag was as almost as good as the hoosier. the hoosier was better,but not by a lot. the hoosier tire had some tread like the et street. The tire that seems to work well for me is the M&H Racemaster cheeter slick low 1.5's all day and now I get 1.42 60's on motor with them. www.intercotire.com I run the 26x11.5x15 on weld drag lights. What works for me may not work for you and so on and so on.
I run the 28/10.5-15S (stiff sidewall) and the car hooks great, I had the Hoosiers before but they weren't stiff sidewall. I just put tubes in my tires now the car reacts alot faster and launches a hell of alot harder. My vote for a M6 would be the stiff sidewall MT's.
