4:30's or 4:56 gears for 28x12.5 e/t streets
Wassup guys, wont be using my nitrous for a while so Im wanting to swap out my 4:11 gears for a set of 4:56's or 4:30's, my 28's are too tall for my 4:11's (all motor runs)...which set of gears would yall recommend for 28" e/t streets? mods are 224 cam, stage 3+ clutch, 12bolt and bolt ons...thanks in advance
Mark
Mark
Closed Sponsor Account
Are you sure they are too tall for the gears?
Like Gator said, what are you looking to make as far as et's and trap speeds go? Those will all be directly affected by tire height and gearing
Also, take into consideration the day the motor sees the juice, you may not want to have to swap gears again...
Erik
Erik
I turn my car to 7200 (limiter at 7400) and with all the playing around on calculators I have done it looks like 4.30 will be the best gear for me on 28's and spray. They aren't going to be as good for motor passes, but I would rather that than run out of gear when I hit the spray.
First,why do you want more gear? better 60? better 1/4mi E.T. I 60 foot 1.42-1.44 motor w/4.11's and a 26'' tire. Loose your cam(too wimpy) The g5x3 cam from LG-motorsports 232/236 drive just the same as your wimpy cam but will make much more power. I gained 3 tenths going from a 224 cam to the x3 cam from LG.
car went 11.7 @ 118 w/ my 4:11 gears and 26x11.5 e/t streets (dont have this tires no more)...on the 100 shot car went 11.1 @ 126 w/ 4:11 gears and 28x12.5 e/t streets...the 11.1 e/t was my first and last run w/ the nitrous then I got booted for not having roll bars...Im now only goin to be running allmotor for a while untill roll bars goes in...w/ the 4:11 and 28's car falls on its face after launching...
Originally Posted by 02SOMWS6
If your going to keep it NA and never spray again go with the 4.56's
If you plan on spraying down the road go with the 4.30's
Mark
