Ram Adj Or Mcleod For Spec 2
Ive Done The Drill Mod And Upgraded The Slave And Master The Trans Has Been Rebuilt From The Dealer.but I Cannot Cleanly Powershift It Is A Little Better With The Drill Mod Its Only Been Three Days So Ill Drive It A Little More To See How That Goes But If That Doesnt Work Im Thinking The Adjustable Master Cylinder.the Clutch Engages A Little Lower Than I Would Like So Maybe That Would Help Im Thinking.im Open For Opinions Please Let Me Know
Did you wrap your clutch line in heater hose? We have a bad problem with boiling the fluid in these cars especially if you have headers. I would just replace your master with a stock GM unit and make it adjustable if you wish.
I like my McLeod, its a good master cylinder. With the low engagement you may want to try bleeding a half a can of fluid through the system first and then give it time, clutches often engage low at first but after a quick break in the engagement will move up some.
Ok your posts are hard to read, stop using caps on the first letter of every word!!!
Just get 2 feet of line and cut it as needed. 5/8 or something in that area should do the trick.
i have the RAM Adj master...i chose it bc it was cheaper than the Mcleod.
Only problem I had was the little ball joint part that goes onto the clutch pedal was too wide, and we couldnt get the clip on. So we just used a dremel and grinded it down a little to get it to fit. Other than that...im pleased, and WS6store had a good deal.
But is the mcleod overkill with my spec 2 clutch set up and is everyone carrying the the new ones that are supposed to be the corrected ones from the old version that everyone was haveing problems with before. And who has the best prices on them right now
Its not overkill, how do you rate master cylinders in terms of "overkill" anyway?
I dont know about there being a corrected version, but FWIW I just rebuilt my Mcleod and its so damn easy, plus once the seals start to leak you will notice it and have plenty of time to plan for the rebuild. The entire rebuild including removal and reinstallation takes like 2 hours.
