Alternator wiring question
Old 09-19-2007, 05:36 PM
brandonppr's Avatar
Default Alternator wiring question
Is it ok to run a power wire from the alternator to the starter then from the starter to the fuse box then from the fuse box to the battery?
I moved the fuse box to inside the car and I am trying to keep wiring at a minimum, but I wanted to make sure it is ok to do it that way.
Also will I be able to kill it with a kill switch and be NHRA legal?
Battery is in the rear and switch would be before battery.
Old 09-20-2007, 12:33 PM
brandonppr's Avatar
TTT
