Keeping A/C on an LS1 240SX?
Old 09-20-2007, 09:47 AM
RideZX-6R's Avatar
Default Keeping A/C on an LS1 240SX?
Just wondering who was able to keep all this stuff as I'd like to as well, what was involved and any tips or tricks they had?
Thanks
Old 09-20-2007, 10:27 AM
natedawg's Avatar
I didn't even want to try it after seeing how much work it would be, but i still have everything to do it if i ever change my mind.
Old 09-20-2007, 11:32 AM
LS240sx's Avatar
personally I dont think it looks to hard. Just take your 240sx lines and have them mated to the LS1 lines. Then use the LS1 reciever drier which I believe houses the high low switch. The ecu controls the A/C clutch. Then just wire your factory on switch to the ecu. Use the 240sx condisor.
Old 09-20-2007, 01:54 PM
Sabre002's Avatar
cant be to hard once you understand how a AC system works. just make sure there is room for the compressior in your car. Then its just a matter of having the lines made and wiring it up. it has been covered many times over on the V8 RX7 forum I'm doing mine this weekend.
Quick Reply: Keeping A/C on an LS1 240SX?
