Desired Shift Time
Old 06-02-2003, 06:58 PM
DeathDealer's Avatar
Default Desired Shift Time
According to the LS1edit manual
Desired Shift Time
This Table sets the desire time to shift. If you set it to zero, it will accelerate transmission wear. You can reduce these values to quicken the shifts.
For a C5 A4 what might be a good setting without being too hard on the tranny?
Old 06-04-2003, 12:25 AM
Default Re: Desired Shift Time
Thanks for the replies. Well I reduced the table by 10 percent and it is much quicker.
Old 06-05-2003, 12:13 PM
BOOSTEDTA's Avatar
wish someone would respond?!?! i've got a Predator and wanted to know if i should adjust the shift time and line pressure, or if i should just change the shift time and leave line pressure alone. i definitely need this tranny to last a few more years (at least)...
Old 06-05-2003, 01:01 PM
SS-35th's Avatar
I have the Predator for my 2002 SS I turned the shift decision time down by 25% and the line pressure up by 5% it shifts fine but I plan on changing the fluid to Royal Purple Synthetic at 15,000 miles and servicing the tranny regularly.
Old 06-05-2003, 11:52 PM
I reduced my line pressure and shift time, very pleased with the crisp results.
Quick Reply: Desired Shift Time
