Need Help
Need Help
2001 Camaro SS, borla cat back, slp intake, 4.10 gears... just wondering what i should do next... would like to put a procharger on eventually. But for now what's next? I've heard heads and cam... but what do you guys think?
depends on your budget, and how much HP you are looking to achieve. you should start with headers, then a cam, then the heads. but if you're thinking procharger, save for that and do it first. i spent as much for the H/C with headers that i would have on the procharger. i would had more power from procharger, at least with the cam i selected. you can get a really big cam with heads and see the same HP as the procharger. you'll also need fuel sytem upgrades. at the least injectors. you've got a long haul and alot of money to spend so think it through first. define what you goals are. after everything i spent it now turns out i will about about $2k in fuel system upgrades, that i thought i had taken care of, but the stuff is insuficiant. good luck
Bill
