Only need decel and idle A/F trims-how???????
I have set closed loop to 300 degrees across the closed loop temp table. I reduced the open loop tables, and the main Ve table to get a just aobut perfect A/F. Oly problems now are decel (13.0:1) and idle A/F (13.5:1). Who knows what map to adjust????
PS. I am usingFJO in car wide band to tune.
I will probably leave the car in open loop if the a/f seems to stay more consistent. Throttle response is now much better.
Thanks
Thanks
