LED Clear Corners?
Sure have.
The turn signal bulb was a regular Autozone replacement, which blew out in 2 days. That's why it's not as bright as the side ones. But those have been replaced as well to LEDs and have lasted me since I've installed them in June. Let me know if you want current pics with the all front LEDs on.
Originally Posted by squirrelishere
Sure have.
I got them from an online LED store. You just need both bulbs, and you can go to Autozone to get the electronic flasher. The stock flasher will burn the LEDs, so you need the electronic one. Not too hard to do since you're basically just replacing your regular bulb and your flasher, no other special stuff required. Let me know if you got any other questions.
Sure have.
