C5 type muffler set up on WS-6?
I want to change to over the axel true duals and want to know if anyone has been able to fab a system with two mufflers in the current stock muffler location (making it similar to a vette set-up). Anyone, sponser or otherwise? Anyone think it will work???
Re: C5 type muffler set up on WS-6?
I have seen someone using them for a side exit setup. As he needed it to come in and go out the same side and needed a small muffler to do the job.
The mufflers used by speed inc aren't C5 type. The C5 type have the inlet on the same end next to the outlet. Therefore you would have to bend and wrap the pipe (not straight through). You can see this type of muffler at speed inc in the corvette exhaust section. BUT, I would think you could install just like you would a C5 BUT flip the mufflers inward instead of outward so the tailpipes are not centerline exiting.
