Textralia- whats the est fly wheel to run with it?
Old 09-23-2007, 12:23 AM
618HAWK's Avatar
Default Textralia- whats the best fly wheel to run with it?
Well its time to replace the clutch, out with the Spec Stg 5 in with a Textralia. Last time I checked you could only get the Textralia as a set, FW-PP-Disc-and slave. Has this changed?
I currently have a Fadenza Alum Flywheel. Is this compatible for the Textralia? Would like to keep it but not a must.
Any connections on a good supplier for the clutch?
Old 09-23-2007, 02:06 AM
caMnaro's Avatar
Byunspeed.com ----------> sponsor. good deals
Old 09-23-2007, 12:20 PM
618HAWK's Avatar
Originally Posted by BYUNSPEED
Nope Chris, you have to ditch the Fidanza and the clutches only come with pressure plate, your choice of disc, flywheel and pressure plate bolts. Initial testing was done with running aftermarket flywheels and it did not work out, hence they came out with their own flywheel bolts.
FYI everyone ... Chris is a good exhaust fabber!
Oh well, The whole setup it should be. Need to get one soon still going to try for the LSX Shootout.
Any insight on there choice of fly wheel, 18# or the 8#, leaning towards the 8# alum. Like the less weight and quicker revs?
What about the differance between the "Z Grip" and "X Grip" dics.
Young shoot me some info on what you can do.......
Finished welding your cage last night.
