Shaft Play Question...
Im about to buy a used sts kit, but the seller has informed me that there is a little bit of shaft play on the exhaust side. He tells me that it moves back and fourth about the thickness of a credit card.
Is this normal? OR is this a problem? Does the turbo need rebuilt or what?
I put a used garrett to4b/t3 on my cousins jetta. Anyway it had alot of shaft play, up and down ,as well as in and out. You need to make sure the fins dont rub the housing as mine didnt. this turbo hit 15 psi no problems. What I cant answer yet is how it will run with new turbo, maybe it will gain some. However to answer your question, ours works fine with alot of shaft play.
If may work alright for a short time but if it has play it is no longer balanced which in the long run it will destroy itself by vibration.
If you insist on purchasing this turbo(for a very reduced price) I would definately rebuild it if it can be rebuilt!
Side to side play is fine and should be there. I think the acceptable tolerance is .018-.022 which feels like a lot (about the thickness of a match book cover), and is necessary for the style of floating journal bearing they use. As log as it not rubbing the housing, your good
When a turbo is dry, and especially when new or after a rebuild it will have shaft play. The oil when pressured is what holds the bearings and firms up the shaft. The ball bearing turbos are what will not have much play at all. If they do then you would need to be concerned.
