Drag Racing Tech
View Poll Results: witch one
275 60 15 mickey thompson
6
26.09%
325 50 15 mickey thompson
17
73.91%
Voters: 23. You may not vote on this poll
275x60MT vs. 325x50MT
Old 09-23-2007, 10:48 PM
Ego Killer's Avatar
Default 275x60MT vs. 325x50MT
I m about to get a set of one or the other..is all the beating and banging worth going a 325? I seen some say they ran better on the 275 60?
Old 09-23-2007, 11:13 PM
Frans96SS's Avatar
i think the 325's look bad *** personally haha.....
Old 09-23-2007, 11:17 PM
gator's 99TA's Avatar
depends on how hard you want to come out of the hole. to me my car loved the 325 radials. also IMO the 275/60 look like a truck tire b/c they are narrow.
Old 09-23-2007, 11:21 PM
Ego Killer's Avatar
thanks Gator,you always seem to answer my questions for me lol..BTW i like the unknown racer quote really makes me think
Old 09-23-2007, 11:36 PM
kp
kp's Avatar
Even though I have ran better on 275/60s then the 325/50 to date the 325 is no doubt a better tire. I had a completely different suspension tuneup when I was was using the 275s that was much more radial friendly.
Old 09-23-2007, 11:58 PM
Ego Killer's Avatar
KP, I know this is WAY off topic but you seem to be the man what gear to you recomend for a around 650-700rwhp(475-500+spray) A3 car around 3500lb car
Old 09-24-2007, 08:10 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I vote for the 325, I like mine.
Old 09-24-2007, 10:26 AM
kp
kp's Avatar
3.70 is a good all around gear with a 28" tire, I have ran this same 3.70 since the car was running 10.40s to present. Really depends on the max rpm and MPH you are expecting to see at your power level. And what size tires of course..
But you also have to consider how important the off the spray ETs are as well, if you want to give up some on the nitrous you can move up to a 3.90 or 4.10 for better NA ETs but you may run out of RPM on the spray.
As far as the tire side there are very few constants in drag racing, but one is wider tired will hook better. May take a few more more HP to pust it down the track but its a good tradeoff for more consistent hooking.
Old 09-24-2007, 03:22 PM
1CAMWNDR's Avatar
325 if you have rims to fit it, and the desire to BFH as needed.
Old 09-27-2007, 11:41 AM
I ruin the end of films...
mongse's Avatar
The 325 will obviously be the better tire, but you can run some good times with a 275. I've seen an LTx car run well into the 5s and cut a 1.3x on a 275. It's all in the suspension setup.
Old 09-27-2007, 11:45 AM
NA$TY-TA's Avatar
Ive had both and the 325's are more forgiving and are just a better tire in my book.
Kyle
Old 09-27-2007, 03:33 PM
kp
kp's Avatar
1.288 60' and 5.81 has been my best on 275/60s, havent made a good pass on a 325s yet but the wheel hop kinda put me off on them. Once I get the car running where I want it I'll fool with the 325s more, but there is no doubt more traction to had with the 325s.
Old 10-11-2007, 12:21 AM
chrismorales75's Avatar
If you can work with the 275 60 15 you'll only have to go low 8's to be competitive =)
325 50 15, you'll have to step up to mid 7's =/
Go with the 325's
Old 10-11-2007, 12:51 AM
WMSuperSport's Avatar
How much more beating and banging is required? I know that's kind of a vague question...
Old 10-11-2007, 06:33 AM
bad2000z's Avatar
Is it just me, or do the 325's seem to fit better on the Firebirds? I mean they don't seem to stick out past the quarters as much as they do on a Camaro. Anybody with a Camaro having trouble with 325's rubbing the quarters at launch?
BTW, I voted for 275's for this reason.
Old 10-11-2007, 07:07 AM
the firebird 1/4 panels are wider.
Old 10-11-2007, 08:11 AM
bad2000z's Avatar
That's what I thought. I noticed a lot of the 325 Camaro guys are narrowed/mini tubbed.
Old 10-11-2007, 01:18 PM
Outlaw's Avatar
https://ls1tech.com/forums/showthrea...61#post7930261
Old 10-11-2007, 09:22 PM
Ego Killer's Avatar
do you have to roll the lip on a firebird?
