Snow Performance Boost Cooler ?
I've tried the seach function but found nothing; I have the Snow Performance Boost Cooler Stage 2 with the digital variable controller and plan on having it installed at the same time as my Procharger. What I'd like to know is for those of you who are running this kit or one similiar what size resevoir are you using and where do you have it mounted? The only answer I've found so far is mounting the battery in the rear and using the oem batter location for the resevoir. Any help will be gratefully appreciated, thanks in advance guys...
I haven't installed mine yet but its the small resevoir and I think you can tuck it up underneath the bumper and still be able to fill it. I haven't looked into it yet though. I plan to move my battery to the back and hopefully be able to fit my A2W resevoir in its place.
Originally Posted by speedracer5532
I use the factory windshield resevoir.
i have seen the tank included in the kit mounted nicely near the fuse boxes or ahead of the stock washer tank off to one side or the other.. but it doesnt hold a heck of a lot.
Websy I didn't even think the 2 qt resevoir that comes with the kit would fit behind the front bumper, I'll have to check that out. Also Mightymouse is that your car on Snow Performance's site? If it is, at the time that the picture was taken were you still using the windshield washer resevoir to hold the meth? Also, I just went outside to take a look how the resevoir might fit near the fuse box or on either side of the windshield washer resevoir, those are both some very tight fitting areas, how did they do it?
