Home built Hot Parts Come on In!
Old 09-24-2007, 01:16 PM
Gordon0652's Avatar
Default Home built Hot Parts Come on In!
Every time i think about upgrading my 2000 t/a FI stays in my mind, does anyone have any experence on building there hot parts except for the headers, i will be buting thoes. And if so how did it go? I would like to do the same for a single turbo kit. My goal would be low 10s in the 1/4 at full weight with a built 4L80E.
Can i get some pictures of your built hot parts any turbo style.
Thank you.
The reason for my building the hot parts is because i like to build what goes on my car, and i like doing all the hard work so that i can have credit for it.
Old 09-24-2007, 01:37 PM
bc56f100's Avatar
I built my own headers but would suggest using the 6.0 manifolds!!! Its real cheap and easy and the work very well!!!
Old 09-24-2007, 01:47 PM
HUNTER02SS's Avatar
I would also suggest you use the truck manifold's. go to the sticky section and look in the truck manifold's. There is a bunch of info in there for you. Some of the fastest f-body's that are turbo'd run truck manifold's!
Old 09-24-2007, 02:28 PM
Gordon0652's Avatar
Aren't those manifolds really restrictive?
And is there anyway to keep my A/C, i should have added that in the beginning of the thread.
Hunter: i was looking at your sig. You have 9xx rwhp and run a 10.7xx. Whats your weight? And do your wheels have trouble hooking. I just would think that having 9xx rwhp you would be faster in the 1/4. Nice ste up by the way!
Old 09-24-2007, 02:49 PM
HUNTER02SS's Avatar
Did you look at my mph? I am trapping 143.31 mph. My car is on stock suspension with a stock 6 speed and a 10bolt and 315-35-17 nitto's. Traction is an issue.
My weight is also 3850 with me in it.
As far as the manifold's being restrictive,yes a little,but they retain the heat needed to make consistant power,and will not crack like some of the header style's will!
Old 09-24-2007, 03:40 PM
frcefed98's Avatar
LOL restrictive. The ohio boys are making 1500+ HP with the truck manifolds and have gone 7's on em....plenty of flow for nearly any of us guys here on the board.
A/C nope, but options might be opening up with the addition of the new BMR turbo K member.
Old 09-24-2007, 04:43 PM
Gordon0652's Avatar
143.31 trap!
1500 hp
Thats crazy esp on stock suspension!
Now i a going to build a low compression LS2 al block 402, 4" x 4" with a pair of mild ported LS6 heads. I was looking into a GT35R turbo, still doing reserch, but i want to keep my car full weight and be in the low to mid 10s. Will that be enought turbo, i looked in to an 88 but that almost cuts it, and with the GT35R i still have room to play unlike the 88.
I was orgional going to go all motor until i did some reserch, and found out a lot i didn't want and want to know, so i talked to eastside and they told me to do some reserch on FI.
Old 09-24-2007, 05:23 PM
HUNTER02SS's Avatar
Some people may disagree with me, But I would go with an iron block, due to the aluminum block under alot of boost distort's from what i have read and heard. Not 100% sure on that, but it is worth looking into!
Old 09-24-2007, 06:45 PM
Gordon0652's Avatar
So you mean like the LQ9 block...?
Old 09-24-2007, 07:52 PM
PLucas's Avatar
I'm building my hot parts right now. Im using the truck manifolds. I really wanted to keep the a/c but truck manifolds are much easier and are proven performers. I am keeping all of my a/c parts to re-install when i make my own headers. The car will be 100% street car.
Old 09-24-2007, 08:04 PM
cjg454ss's Avatar
yeah 10.7s is not very fast for that hp, Take a look at Na$ty TA s setup. big single,
Old 09-24-2007, 08:26 PM
HUNTER02SS's Avatar
Once again mph tell's hp! 10.7 say's I am spinning half track!When I get the STOCK part's replace I will be where I want to be!!
Old 09-24-2007, 08:27 PM
HUNTER02SS's Avatar
Yes! I think 2000 and up block's are the better one's to get. Not sure why?
Old 09-24-2007, 08:42 PM
Gordon0652's Avatar
I looked into an AL LS2 block, and it can only handle about 650-700hp. Some guys have done 1000hp and it stayed intack. Apperently the LQ9 is a proven performer, it can handle about 1000hp. And its about 400-500 $$$$$$ cheaper but on the other hand it weighs 82 more pounds. So the LQ9 is a better choice!
One more question, will i have to relocate the radiator, i know i will have to buy an aftermarket one.
Old 09-24-2007, 09:11 PM
HUNTER02SS's Avatar
Your radiator should be fine? Depend's on the size turbo though! The block will handle more than 1000hp. Ohio boy's are at 1500hp on there iron block!
Old 09-24-2007, 10:40 PM
Gordon0652's Avatar
Thank you For the help everyone!!!
Old 09-25-2007, 08:33 AM
bc56f100's Avatar
Haha try messin with him on the street!!!
You might have to end up cutting your core support out to and set your radiator upright!! Theres a great circle track radiator and fans that fit perfect if you go that rout!! Just let me know and I can find the part numbers!!
Old 09-25-2007, 10:02 AM
JAvenger007's Avatar
Not true at all. Many guys running 700+ with LS1 blocks and just as much with LS2. If 1k hp is really your goal, look into an iron block.
Old 09-25-2007, 11:00 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'm 9.4 with truck manifolds and 2001 era LS6 block, 8:1. You can easily run mid 9's with an aluminum block.
Old 09-25-2007, 11:26 AM
7 Second Club
Phil99vette's Avatar
Check out my thread in drag racing tech(25.5 Mustang Build) On page 1 or 2 there are some very good pics of the hot side parts as they were built.
Phil
Quick Reply: Home built Hot Parts Come on In!
