Dynamometer Results & Comparisons - 383 le2 h/c/i numbers
View Full Version : 383 le2 h/c/i numbers
sheikss
09-24-2007, 08:45 PM
Got the car to Ed today. Despite a alt. that was new dying, bad gas, and getting a miss at the end I still managed 436.9 rwhp and 407.2 rwtq. I figure there is 1 or 2 more left once I fix the miss and get another new alt. I've got a few other little things mainly with the compression being higher than I thought so I will need to find a way to raise the octane alittle. Numbers were through a 6 speed and 3.42 10 bolt.
venom ws7
09-24-2007, 10:31 PM
More info PLZ
H/C/I CR Boltons?????
sheikss
09-24-2007, 10:43 PM
It's a speed inc shortblock, electric waterpump, stepped kooks headers, le 3.2 cam, 58mm tb, 30 svo's, 3 inch off rd y-pipe, tsp rumbler exhaust, dynaspark, as for the compression I have no idea due to the fact that speed inc never sent a spec sheet. I know it likes more octane than 91 pump. Don't remember the flow numbers on the heads and I had the intake ported also. Oh and a 4 inch aluminum driveshaft. Is that enough?
sheikss
09-24-2007, 10:45 PM
Oh I got to regape the plugs and I used impala head gaskets. Racetronics boost-a-pump, Ram stage 4 clutch, asp 20% underdrive which I plan to place due to the fact that I have a small vibration, which I think is being caused by my flywheel being for a normal lt1. I've got call speed inc and see in they internally or externally balance the 383 lt1 shortblocks.
Elysian
09-27-2007, 03:29 PM
: ) Nice numbers.
What are the approximate specs on the cam? Head flow numbers? Did you ever figure out the final compression ratio?
roadtrip120
09-27-2007, 04:12 PM
pretty good numbers, what was the compression
I built a 385 for a friend
Le2 heads, Le intake, le3 cam
11.8 compression
Full bolt-on's, 85mm MAF, LT's, EWP, 58mm TB,Aluminum flywheel.
M6, 10 bolt 3.42
466rwhp 449rwtq
flyinZ
09-27-2007, 06:27 PM
B-Rad, who ended up tuning that 385 of your buddies?? And your own if you dont mind me askin'?
sheikss
09-27-2007, 06:29 PM
I have no idea what the compression is due to the fact the speed inc would never send me a spec sheet which I requested when I bought the block. Right now I have a slight vibration which I believe is being caused by the flywheel so I'm going to get the flywheel and clutch balanced. I called speed inc once I realized I had a vibration and asked if they balance their stroker motors internally or externally and the answer I got was,"Yea, I'm pretty sure we balance internally". I told them I had a ram stage 4 in it and they said to balance the clutch and flywheel. Oh these numbers aren't through duals their through a normal tsp rumbler. I think once the altenator is replaced, the plugs get gapped correctly and I get the miss taken car of it will make alittle more. The new alt died on like the 3rd run and then the miss came back.
sheikss
09-27-2007, 06:32 PM
What do you guys think a set of duals, a smooth bellow from the throttle body to the airbox, and descreening and porting the ends on the mass air would be worth? Oh I'm using and ultra z hood and airbox. Ed worked on the tune from about 9 in the morning till almost 4 in the evening so alot of props to Ed Wright.
roadtrip120
09-27-2007, 08:11 PM
PCm for less did the 385 base tune, and i fine tuned it on the dyno.
I have been doing the same, pcmforless, and myself on the dyno..
I'm looking at a FAST XFI on my new setup, i'll probably have Boost Performance here in Amarillo tune it.
LS1 SPEED
09-28-2007, 08:23 AM
please email me today
I can get you close on your compression with a little info.
I am sure it is upwards of high 11's though and 91 octane is border line.
get me the following :
CC of head.. is the 57cc correct ?
Gasket used
I am sorry about not getting you a spec sheet, but the builder never supplied us with one either.
hope to hear from you today
