Intake Gasket Questions
Old 09-25-2007, 12:54 AM
Chance883's Avatar
Default Intake Gasket Questions
I have a 94 LT1 and I just did a top end build on it. When I had my heads rebuilt they had to shave 30 thousandths off because of warpage. Now When I reinstalled the intake there is a gap thick enough to put a quarter in at the front and the back of the intake. How am I going to keep this from leaking oil? Thanks.
Old 09-25-2007, 04:05 AM
Formula_LT1's Avatar
Really? I think mine are shaved like .030 or .035 and I haven't run into any problems? What kind of head gasket are you using? Do you know how thick it is?
Old 09-25-2007, 08:58 AM
csjta2's Avatar
RTV Silicone
Old 09-25-2007, 09:37 AM
AR15 guy's Avatar
RTV is your friend. Mine was shaved more than that and I had no problems.
Old 09-25-2007, 04:15 PM
Chance883's Avatar
They are stock felpro gaskets. I was also wondering if I would have a problem with clearance issues? I put an LT4 hot cam, and 1.6 rrs in it.
Old 09-25-2007, 05:00 PM
koolaid_kid's Avatar
The front and back were sealed with RTV, not gaskets.
Old 09-25-2007, 09:05 PM
Chance883's Avatar
Thats correct, but now since the heads were shaved it has more of a gap than stock.
Old 09-25-2007, 09:16 PM
No I have a much bigger cam w/out any issues so far. Put over 4k on the setup, and I'd say it would have made some noises by now.
Old 09-26-2007, 04:31 PM
speed_demon24's Avatar
Milling the heads shouldn't lift the intake manifold higher off the block at all, and if it did something is wrong.
Old 09-26-2007, 04:56 PM
Chance883's Avatar
It might have always had that much of a gap, but I never noticed it. How much of a gap should there be?
Quick Reply: Intake Gasket Questions
