Automatic Get me more MPH????
Old 09-25-2007, 08:54 AM
HUNTER02SS's Avatar
Default Automatic Get me more MPH????
I have a 6 speed now and if I switch to a TH400 will the auto get me more mph?? Some i have talked to say yes and some say no? I am confused. Anybody from experience know!
Old 09-25-2007, 09:02 AM
LS1Tech Sponsor
performabuilt's Avatar
I would say no for several reasons particularly with the 400 , 1- lower final ratio one to one in third gear. Add to that a high stall and no lockup and you have considerable waste in converter slip. At your HP and Torque level if want to go auto and still retain efficiency I would consider the 4L80E as a good alternative.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 09-25-2007, 04:36 PM
c0ncEpT's Avatar
most people loose a few mph(1-3 from what I have seen) but they get a drop in ET also
Old 09-25-2007, 07:05 PM
josh2002-ws6's Avatar
I am doing the same but going with a 4L80E instead of the TH400. I have heard of losing MPH but getting big gains in ET's. A friend just put a nice stall on his 4L60E from stock and went from a 12.78 to a 12.13. So the stall does a lot i think.
Old 09-25-2007, 08:17 PM
DanZ28's Avatar
I went from 120.4 mph to 125.8 mph going from M6 to TH400. I also changed the cam though from a 230/234(M6) to the TRex (TH400). I don't see any M6's out there at my track out MPH'ing me though with a similar setup and weight...
Dan
Old 09-25-2007, 10:41 PM
cablebandit's Avatar
Chris, locking my converter, it "SHOULD" take me about 14psi to run your mph.....we will see soon enuff so you can do some comparing
