Safety Rules?
You need a single layer jacket, Snell K98 or newer helmet, 5pt minimum roll bar, 5pt harness, driveshaft loop, radiator overflow (stock is fine), secure battery, proper wheel studs/nuts, functional neutral safety switch and thats about it really.
Local NHRA track has been checking for rubber transmission hose, even short sections to a cooler. Rulebook says steel or high pressure hose only.
