97-02 rear tillights
i think you have to change the wiring harness.. where your plugs with the bulbs on your 95 would have to get switched with the newer ones.. if im right your 95 plugs wont twist on properly to the backside of the newer lamps
Originally Posted by FAD2BLK93
PLUG-N-PLAY...direct swap
the sockets are different 93-96 and 97-02
you also need the 5th wire spliced into the harness from the brake switch (blue wire)
back to the taillight harness.
http://www.bfranker.badz28.com/fbody/97lights.htm
