t-5 rebuild
Old 09-26-2007, 08:30 PM
blackangel327's Avatar
Default t-5 rebuild
does anyone know where i can get a t5 rebuild kit that replaces all the gears and stuff but is WAY stronger than stock? i know that the stock ones can handle around 320 Ft lbs of torque, but i want it higher than that.
thanks!
Black Angel
Old 09-26-2007, 08:48 PM
IMD
IMD's Avatar
pm thesource on this board.
Old 09-27-2007, 08:43 AM
thesource's Avatar
What are you putting in ? GM or Ford or a hybrid ?
Old 09-27-2007, 08:53 AM
ls1 joe's Avatar
D&D Performance. They have them.
Amber
Old 09-27-2007, 09:15 AM
thesource's Avatar
D&D sells the T5Z gears which are stronger than stock but probably not what you are looking for . I would go with the Astro Performance A5 gear set . Its available in either Ford Mustang or GM 3rd gen Camaro applications . It does require a 26 spline clutch disc like the T56 or older GM 4 spds . PM me on details or give Tony @ Astro Performance (866-253-0019) a call and tell him Mike at Texas Motorsports gave you his number .........
